Inleiding
Use this guide to replace the ear speaker of the Samsung Mythic SGH-a897.
Wat je nodig hebt
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
Carefully remove the camera from the phone's motherboard.
Use tweezers to unclip the silver connector.
Then put pressure on the black latch which is circled to release the speaker.
