Inleiding
This guide will give instructions on removing the daughterboard from the motherboard in the Samsung Mythic SGH-a897. Tweezers are used to successfully remove the daughterboard from the motherboard by unclipping a connector.
Wat je nodig hebt
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
Carefully remove the camera from the phone's motherboard.
