Ga door naar hoofdinhoud
Samsung MV900F Flash Bulb Assembly Replacement
Wat je nodig hebt
  1. Samsung MV900F Flash Bulb Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the lock towards the middle of the camera, in the same direction of the arrow.
  2. Samsung MV900F Flash Bulb Assembly Replacement: stap 2, afbeelding 1 van 1
    • Push the blue battery holder up in the direction of the arrow.
  3. Samsung MV900F Flash Bulb Assembly Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery out of the battery slot.
  4. Samsung MV900F Flash Bulb Assembly Replacement, Screen: stap 4, afbeelding 1 van 2 Samsung MV900F Flash Bulb Assembly Replacement, Screen: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to remove the four rubber screw covers.
  5. Samsung MV900F Flash Bulb Assembly Replacement: stap 5, afbeelding 1 van 2 Samsung MV900F Flash Bulb Assembly Replacement: stap 5, afbeelding 2 van 2
    • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
  6. Samsung MV900F Flash Bulb Assembly Replacement: stap 6, afbeelding 1 van 1
    • Remove the back casing by just carefully pulling the casing off of the camera.
  7. Samsung MV900F Flash Bulb Assembly Replacement: stap 7, afbeelding 1 van 1
    • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
  8. Samsung MV900F Flash Bulb Assembly Replacement: stap 8, afbeelding 1 van 1
    • Use plastic opening tool to disconnect screen connector from the control board.
  9. Samsung MV900F Flash Bulb Assembly Replacement: stap 9, afbeelding 1 van 1
    • Remove the old screen.
  10. Samsung MV900F Flash Bulb Assembly Replacement, Lens Assembly: stap 10, afbeelding 1 van 1
    • Remove the 2.381 mm screw with a Phillips #00 screwdriver.
  11. Samsung MV900F Flash Bulb Assembly Replacement: stap 11, afbeelding 1 van 1
    • Use the plastic opening tool to remove the silver metal lens cover.
  12. Samsung MV900F Flash Bulb Assembly Replacement: stap 12, afbeelding 1 van 1
    • Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
  13. Samsung MV900F Flash Bulb Assembly Replacement: stap 13, afbeelding 1 van 1
    • From the front of the camera, push the lens through the back of the camer.a
  14. Samsung MV900F Flash Bulb Assembly Replacement: stap 14, afbeelding 1 van 2 Samsung MV900F Flash Bulb Assembly Replacement: stap 14, afbeelding 2 van 2
    • Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
  15. Samsung MV900F Flash Bulb Assembly Replacement: stap 15, afbeelding 1 van 2 Samsung MV900F Flash Bulb Assembly Replacement: stap 15, afbeelding 2 van 2
    • Remove the lens assembly from the camera.
  16. Samsung MV900F Flash Bulb Assembly Replacement, Flash Bulb Assembly: stap 16, afbeelding 1 van 1
    • Remove the 2.381 mm screw that is holding the copper to the control board with a Phillips #00 screw driver.
  17. Samsung MV900F Flash Bulb Assembly Replacement: stap 17, afbeelding 1 van 1
    • Use tweezers to pull copper connector from the control board.
  18. Samsung MV900F Flash Bulb Assembly Replacement: stap 18, afbeelding 1 van 1
    • Use the plastic opening tool to pry the control board up, thus allowing the flash bulb assembly to be removed.
  19. Samsung MV900F Flash Bulb Assembly Replacement: stap 19, afbeelding 1 van 1
    • Beginning with the battery on the side, gently pull upwards to remove the entire flash bulb assembly.
Conclusie
Justin Smith
110 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 510
