Ga door naar hoofdinhoud
Samsung ML2510 Rear Cooling Fan Replacement
Wat je nodig hebt
  1. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: stap 1, afbeelding 1 van 3 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: stap 1, afbeelding 2 van 3 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: stap 1, afbeelding 3 van 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Rear Cooling Fan Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Rear Cooling Fan Replacement: stap 3, afbeelding 1 van 3 Samsung ML2510 Rear Cooling Fan Replacement: stap 3, afbeelding 2 van 3 Samsung ML2510 Rear Cooling Fan Replacement: stap 3, afbeelding 3 van 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: stap 4, afbeelding 1 van 2 Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: stap 4, afbeelding 2 van 2
    • Once the fan is detached, unplug the fan from the circuit board.
    • Slide the fan's wiring through the anchored slit.
  5. Samsung ML2510 Rear Cooling Fan Replacement: stap 5, afbeelding 1 van 1
    • With the new fan, thread the wiring through the old fan's slit.
    • Reconnect the fan by plugging it back into the circuit board.
    • Reattach the back panel following these instructions in reverse order.
Eindstreep
bbaustin
268 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-18, Regan Fall 2011 Lid van Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Leden
12 handleidingen geschreven
Één opmerking
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
Bax Bagatelli - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 3,339
