Inleiding
This guide will go over where to locate and replace the rear cooling fan. You will need to reference the Removing Samsung ML2510 Back Panel repair guide to complete this one.
Gereedschap
Onderdelen
Geen onderdelen nodig.
Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
Once the fan is detached, unplug the fan from the circuit board.
Slide the fan's wiring through the anchored slit.
Één commentaar
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
