Wat je nodig hebt
Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95
Using the anti-static wrist strap and the metal spudger, remove the wires from the speakers.
6 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Só tem esse video que mostra passo a passo como desmontar o Samsung Level Box Mini.
Obrigado por compartilhar amigo, espero que esse video ajude outras pessoas.
