Ga door naar hoofdinhoud
Samsung LN-T5265F T-Con Board Replacement
Wat je nodig hebt
  1. Samsung LN-T5265F T-Con Board Replacement, Stand: stap 1, afbeelding 1 van 1
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Samsung LN-T5265F T-Con Board Replacement, Rear Case: stap 3, afbeelding 1 van 2 Samsung LN-T5265F T-Con Board Replacement, Rear Case: stap 3, afbeelding 2 van 2
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
  3. Samsung LN-T5265F T-Con Board Replacement, T-Con Board: stap 4, afbeelding 1 van 2 Samsung LN-T5265F T-Con Board Replacement, T-Con Board: stap 4, afbeelding 2 van 2
    • The Timing Controller (T-Con) board is located at the top center behind a metal shield.
    • Remove four Phillips screws.
    • Tilt the metal shield towards the top of the TV and lift away.
  4. Samsung LN-T5265F T-Con Board Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the two ribbon cables at the top by flipping up the retaining flaps and sliding the ribbons straight up towards the top of the TV.
  5. Samsung LN-T5265F T-Con Board Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the bottom ribbon cable by depressing the two buttons on either side of the connector and sliding down towards the bottom of the TV.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Steven Carlton
606 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 10,057
