Onderdelen
Geen onderdelen nodig.
  1. Lay the TV screen-side down on a flat, soft surface.
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    • Slide the stand out from the bottom of the TV.
  3. Remove fifteen Phillips screws securing the rear case to the front. If present, remove four Phillips screws for the VESA mount.
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Steven Carlton
590 Reputatie
3 handleidingen geschreven
Één commentaar
The guide says that 15 Phillips screws have to be removed from the back. The actual number of the Phillips screws is indeed 15. However, the supplied picture marks locations of 14 Phillips screws only. The 15th screw is located near the left edge of the rear connector cluster. It has to be removed as well.
Andrey - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 5
Altijd: 1,862
