Ga door naar hoofdinhoud
Samsung L100 LCD Screen Replacement
Wat je nodig hebt
  1. Samsung L100 LCD Screen Replacement, Removing Back Cover: stap 1, afbeelding 1 van 3 Samsung L100 LCD Screen Replacement, Removing Back Cover: stap 1, afbeelding 2 van 3 Samsung L100 LCD Screen Replacement, Removing Back Cover: stap 1, afbeelding 3 van 3
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Samsung L100 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 LCD Screen Replacement: stap 3, afbeelding 1 van 3 Samsung L100 LCD Screen Replacement: stap 3, afbeelding 2 van 3 Samsung L100 LCD Screen Replacement: stap 3, afbeelding 3 van 3
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 1 van 2 Samsung L100 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 2 van 2
    • Remove the screws holding the circuit board.
    • Carefully remove the circuit board.
  7. Samsung L100 LCD Screen Replacement: stap 7, afbeelding 1 van 2 Samsung L100 LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Carefully lift circuit board from camera.
    • Circuit board still attached to camera by ribbon.
  8. Samsung L100 LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Remove the front cover. It should come off easily.
    • Buttons might fall out when you remove the front cover.
  9. Samsung L100 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Samsung L100 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Remove the green tape that holds the LCD screen.
    • Carefully lift the LCD Screen.
  10. Samsung L100 LCD Screen Replacement: stap 10, afbeelding 1 van 3 Samsung L100 LCD Screen Replacement: stap 10, afbeelding 2 van 3 Samsung L100 LCD Screen Replacement: stap 10, afbeelding 3 van 3
    • Flip the camera over to the other side.
    • Lift the black strip and the ribbon should easily come out.
    • The LCD Screen should be completely separated from the camera now.
  11. Samsung L100 LCD Screen Replacement: stap 11, afbeelding 1 van 2 Samsung L100 LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • Insert the new LCD Screen by pushing the ribbon into the slot.
    • Flip the black strip back down to lock the ribbon in.
    • Your new LCD Screen should be connected to the camera now.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hasit
207 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-17, Maness Spring 2010 Lid van Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 6,367
