Ga door naar hoofdinhoud
Samsung Juke SCH-u470 Keyboard Replacement
Wat je nodig hebt
  1. Samsung Juke SCH-u470 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke SCH-u470 Keyboard Replacement: stap 2, afbeelding 1 van 2 Samsung Juke SCH-u470 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke SCH-u470 Keyboard Replacement, Camera/Speaker: stap 3, afbeelding 1 van 1
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke SCH-u470 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke SCH-u470 Keyboard Replacement: stap 5, afbeelding 1 van 3 Samsung Juke SCH-u470 Keyboard Replacement: stap 5, afbeelding 2 van 3 Samsung Juke SCH-u470 Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke SCH-u470 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke SCH-u470 Keyboard Replacement: stap 7, afbeelding 1 van 2 Samsung Juke SCH-u470 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke SCH-u470 Keyboard Replacement: stap 8, afbeelding 1 van 2 Samsung Juke SCH-u470 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Use the iFixit opening tool to gently pry the camera/speaker off.
  9. Samsung Juke SCH-u470 Keyboard Replacement, Motherboard: stap 9, afbeelding 1 van 2 Samsung Juke SCH-u470 Keyboard Replacement, Motherboard: stap 9, afbeelding 2 van 2
    • Use the iFixit opening tool to remove the yellow tab on the motherboard.
  10. Samsung Juke SCH-u470 Keyboard Replacement: stap 10, afbeelding 1 van 2 Samsung Juke SCH-u470 Keyboard Replacement: stap 10, afbeelding 2 van 2
    • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
  11. Samsung Juke SCH-u470 Keyboard Replacement: stap 11, afbeelding 1 van 3 Samsung Juke SCH-u470 Keyboard Replacement: stap 11, afbeelding 2 van 3 Samsung Juke SCH-u470 Keyboard Replacement: stap 11, afbeelding 3 van 3
    • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
    • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
  12. Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: stap 12, afbeelding 1 van 3 Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: stap 12, afbeelding 2 van 3 Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: stap 12, afbeelding 3 van 3
    • Open/swivel the phone so the back of the LCD panel is visible.
    • Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
    • A moderate amount of force may need to be applied.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Renee Kuzniar
94 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-18, Maness Spring 2010 Lid van Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 19
Altijd: 1,972
