Ga door naar hoofdinhoud
Samsung Instinct Camera Replacement
Wat je nodig hebt
  1. Samsung Instinct Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Camera Replacement: stap 2, afbeelding 1 van 1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Camera Replacement, Back Case: stap 3, afbeelding 1 van 1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Camera Replacement: stap 4, afbeelding 1 van 2 Samsung Instinct Camera Replacement: stap 4, afbeelding 2 van 2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Camera Replacement: stap 5, afbeelding 1 van 1
    • Lift the casing off of the phone.
  6. Samsung Instinct Camera Replacement, Antenna: stap 6, afbeelding 1 van 1
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Camera Replacement: stap 7, afbeelding 1 van 1
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Camera Replacement: stap 8, afbeelding 1 van 1
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Camera Replacement: stap 9, afbeelding 1 van 1
    • Gently lift up on the antenna and remove it from the back of the device.
  10. Samsung Instinct Camera Replacement, Front Case: stap 10, afbeelding 1 van 1
    • Remove the two 3.50mm screws connecting the motherboard to the case.
  11. Samsung Instinct Camera Replacement: stap 11, afbeelding 1 van 3 Samsung Instinct Camera Replacement: stap 11, afbeelding 2 van 3 Samsung Instinct Camera Replacement: stap 11, afbeelding 3 van 3
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
  12. Samsung Instinct Camera Replacement: stap 12, afbeelding 1 van 1
    • Lift out the top right ribbon from its slot on the motherboard.
  13. Samsung Instinct Camera Replacement: stap 13, afbeelding 1 van 2 Samsung Instinct Camera Replacement: stap 13, afbeelding 2 van 2
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  14. Samsung Instinct Camera Replacement: stap 14, afbeelding 1 van 1
    • Lift the motherboard away from the front casing.
  15. Samsung Instinct Camera Replacement: stap 15, afbeelding 1 van 1
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
  16. Samsung Instinct Camera Replacement, Motherboard: stap 16, afbeelding 1 van 3 Samsung Instinct Camera Replacement, Motherboard: stap 16, afbeelding 2 van 3 Samsung Instinct Camera Replacement, Motherboard: stap 16, afbeelding 3 van 3
    • Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
    • There are three strips total: one on the right, left, and top of the phone.
  17. Samsung Instinct Camera Replacement: stap 17, afbeelding 1 van 1
    • Using the plastic opener tool, pry the speaker connector away from the back of the motherboard.
  18. Samsung Instinct Camera Replacement: stap 18, afbeelding 1 van 1
    • Using the plastic opener tool, remove the speaker from its setting.
    • Pry where the wire enters the speaker.
    • The speaker has adhesive on the bottom, thus removing it will require a bit of wiggling.
  19. Samsung Instinct Camera Replacement: stap 19, afbeelding 1 van 1
    • Gently lift the motherboard from the center frame.
  20. Samsung Instinct Camera Replacement, Camera: stap 20, afbeelding 1 van 1
    • Once the motherboard is removed from the frame, use the pry tool to remove the camera.
    • Insert the pry bar between the camera and the frame then lift up.
    • The camera is held in by adhesive so it will require some force to remove.
    • You have now successfully removed the camera from your Samsung Instinct.
Conclusie
Patrick
75 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-13, Regan Fall 2011 Lid van Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 864
