Ga door naar hoofdinhoud
Samsung Instinct Antenna Replacement
Wat je nodig hebt
  1. Samsung Instinct Antenna Replacement, Battery: stap 1, afbeelding 1 van 1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Antenna Replacement: stap 2, afbeelding 1 van 1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Antenna Replacement, Back Case: stap 3, afbeelding 1 van 1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Antenna Replacement: stap 4, afbeelding 1 van 2 Samsung Instinct Antenna Replacement: stap 4, afbeelding 2 van 2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Antenna Replacement: stap 5, afbeelding 1 van 1
    • Lift the casing off of the phone.
  6. Samsung Instinct Antenna Replacement, Antenna: stap 6, afbeelding 1 van 1
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Antenna Replacement: stap 7, afbeelding 1 van 1
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Antenna Replacement: stap 8, afbeelding 1 van 1
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Antenna Replacement: stap 9, afbeelding 1 van 1
    • Gently lift up on the antenna and remove it from the back of the device.
Conclusie
Jimmy Kuo
14 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-13, Regan Fall 2011 Lid van Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,069
