Ga door naar hoofdinhoud
Samsung Impression Keyboard Replacement
Wat je nodig hebt
  1. Samsung Impression Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    Vraag FixBot
  2. Samsung Impression Keyboard Replacement: stap 2, afbeelding 1 van 2 Samsung Impression Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    Vraag FixBot
  3. Samsung Impression Keyboard Replacement, Back Cover: stap 3, afbeelding 1 van 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    Vraag FixBot
  4. Samsung Impression Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    Vraag FixBot
  5. Samsung Impression Keyboard Replacement, Circuit Board: stap 5, afbeelding 1 van 1
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
    Vraag FixBot
  6. Samsung Impression Keyboard Replacement: stap 6, afbeelding 1 van 2 Samsung Impression Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Gently tug the black and blue ribbon upwards to release the circuit board.
    Vraag FixBot
  7. Samsung Impression Keyboard Replacement, Antenna: stap 7, afbeelding 1 van 2 Samsung Impression Keyboard Replacement, Antenna: stap 7, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the six 3.5 mm screws by rotating.
    • The antenna assembly will snap off.
    Vraag FixBot
  8. Samsung Impression Keyboard Replacement, Keyboard: stap 8, afbeelding 1 van 1
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
    Vraag FixBot
  9. Samsung Impression Keyboard Replacement: stap 9, afbeelding 1 van 2 Samsung Impression Keyboard Replacement: stap 9, afbeelding 2 van 2
    • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
    • Separate the silver plate and phone frame (fig. 2).
    Vraag FixBot
  10. Samsung Impression Keyboard Replacement: stap 10, afbeelding 1 van 1
    • The silver piece you are left with is the physical keyboard assembly.
    Vraag FixBot
Conclusie
Ross McKelvie
196 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-10, Regan Spring 2011 Lid van Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Leden
23 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 56
Altijd: 2,649
