Ga door naar hoofdinhoud
Samsung Impression Digitizer or Front Buttons Replacement
Wat je nodig hebt
  1. Samsung Impression Digitizer or Front Buttons Replacement, Battery: stap 1, afbeelding 1 van 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Impression Digitizer or Front Buttons Replacement: stap 2, afbeelding 1 van 2 Samsung Impression Digitizer or Front Buttons Replacement: stap 2, afbeelding 2 van 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Impression Digitizer or Front Buttons Replacement, Back Cover: stap 3, afbeelding 1 van 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Impression Digitizer or Front Buttons Replacement: stap 4, afbeelding 1 van 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Impression Digitizer or Front Buttons Replacement, Circuit Board: stap 5, afbeelding 1 van 1
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Impression Digitizer or Front Buttons Replacement: stap 6, afbeelding 1 van 2 Samsung Impression Digitizer or Front Buttons Replacement: stap 6, afbeelding 2 van 2
    • Gently tug the black and blue ribbon upwards to release the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Impression Digitizer or Front Buttons Replacement, Keyboard: stap 7, afbeelding 1 van 1
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Impression Digitizer or Front Buttons Replacement: stap 8, afbeelding 1 van 2 Samsung Impression Digitizer or Front Buttons Replacement: stap 8, afbeelding 2 van 2
    • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
    • Separate the silver plate and phone frame (fig. 2).
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung Impression Digitizer or Front Buttons Replacement: stap 9, afbeelding 1 van 1
    • The silver piece you are left with is the physical keyboard assembly.
    Vraag FixBot
    Voeg opmerking toe
  10. Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: stap 10, afbeelding 1 van 2 Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: stap 10, afbeelding 2 van 2
    • Remove the 3 screws holding down the flex cable.
    • The two screws on the black frame are 2.0 mm in length.
    • The top right screw that goes through the circle port on the flex cable is 2.3 mm.
    • Remove the keyboard slider frame. The flex cable should be exposed, but not free.
    Vraag FixBot
    Voeg opmerking toe
  11. Samsung Impression Digitizer or Front Buttons Replacement: stap 11, afbeelding 1 van 1
    • Remove the four 3.5 mm outer screws.
    Vraag FixBot
    Voeg opmerking toe
  12. Samsung Impression Digitizer or Front Buttons Replacement: stap 12, afbeelding 1 van 3 Samsung Impression Digitizer or Front Buttons Replacement: stap 12, afbeelding 2 van 3 Samsung Impression Digitizer or Front Buttons Replacement: stap 12, afbeelding 3 van 3
    • Slide the phone apart and remove the 3.5 mm screw on the top middle (fig. 1).
    • Remove the outer shell by prying the edges off with your fingers or a small screwdriver (fig. 2).
    • The device will now be in two pieces (fig. 3).
    Vraag FixBot
    Voeg opmerking toe
  13. Samsung Impression Digitizer or Front Buttons Replacement: stap 13, afbeelding 1 van 2 Samsung Impression Digitizer or Front Buttons Replacement: stap 13, afbeelding 2 van 2
    • Lift the tab underneath the blue tape and gently pull the flex cable (fig. 1).
    • The flex cable will now be completely free (fig. 2).
    Vraag FixBot
    Voeg opmerking toe
  14. Samsung Impression Digitizer or Front Buttons Replacement, Ear Speaker: stap 14, afbeelding 1 van 1
    • Remove the 2.3 mm screw.
    • Lift the black tab at the end of the ribbon.
    • Gently pull the speaker and ribbon free.
    Vraag FixBot
    Voeg opmerking toe
  15. Samsung Impression Digitizer or Front Buttons Replacement, LCD: stap 15, afbeelding 1 van 2 Samsung Impression Digitizer or Front Buttons Replacement, LCD: stap 15, afbeelding 2 van 2
    • Lift the remaining two tabs and free their respective ribbon cables.
    • Gently pry the screen away from the housing.
    • Be careful with this step as you are in direct contact with the LCD screen.
    Vraag FixBot
    Voeg opmerking toe
  16. Samsung Impression Digitizer or Front Buttons Replacement, Digitizer or Front Buttons: stap 16, afbeelding 1 van 1
    • If replacing the front buttons, remove the assembly at the bottom of the front panel
    • The digitizer is now free to be pulled out from the front housing.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Saul Villatoro
260 Reputatie
7 handleidingen geschreven
Cal Poly, Team 8-10, Regan Spring 2011 Lid van Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Leden
45 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 36
Altijd: 7,249
