Ga door naar hoofdinhoud
Samsung Impression Back Cover Replacement
Wat je nodig hebt
  1. Samsung Impression Back Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
  2. Samsung Impression Back Cover Replacement: stap 2, afbeelding 1 van 2 Samsung Impression Back Cover Replacement: stap 2, afbeelding 2 van 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
  3. Samsung Impression Back Cover Replacement, Back Cover: stap 3, afbeelding 1 van 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
  4. Samsung Impression Back Cover Replacement: stap 4, afbeelding 1 van 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
Conclusie
Saul Villatoro
260 Reputatie
7 handleidingen geschreven
Cal Poly, Team 8-10, Regan Spring 2011 Lid van Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Leden
23 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 54
Altijd: 1,856
