Ga door naar hoofdinhoud
Inleiding
For the user to remove the camera lens of the Samsung HMX-W200, they will first need to remove the components protecting the lens.
  1. Remove the 5.00mm screw on the right of the LCD display  towards the bottom of the device by using a Phillips #00 screwdriver.
    • Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
  2. Use the plastic opening tool to separate and remove the bottom red casing. Do this by, pushing the tool into the seam and prying up the red casing as you move along the edges. Make sure to separate all the corners before removing the red casing. Make sure to separate all the corners before removing the red casing.
    • Use the plastic opening tool to separate and remove the bottom red casing. Do this by, pushing the tool into the seam and prying up the red casing as you move along the edges.
    • Make sure to separate all the corners before removing the red casing.
  3. Using the plastic opening tool, separate and pull away the red casing on the right of the LCD screen. Make sure to separate all the corners before removing the red casing.
    • Using the plastic opening tool, separate and pull away the red casing on the right of the LCD screen.
  4. To access the HDMI slot, move slider towards the bottom of the casing on the other side of the camcorder. The lid casing will lift up upon doing so. After accessing the HDMI slot you will find a 5.00mm screw. Using a Phillips #00 screwdriver, remove the screw.
    • To access the HDMI slot, move slider towards the bottom of the casing on the other side of the camcorder. The lid casing will lift up upon doing so.
    • After accessing the HDMI slot you will find a 5.00mm screw. Using a Phillips #00 screwdriver, remove the screw.
  5. Using the plastic opening tool, separate and pull away the red casing to the left of the LCD screen. Make sure to separate all the corners before removing the red casing.
    • Using the plastic opening tool, separate and pull away the red casing to the left of the LCD screen.
  6. Remove the six 5.00mm screws by using a Phillips #00 screwdriver. Remove the six 5.00mm screws by using a Phillips #00 screwdriver.
    • Remove the six 5.00mm screws by using a Phillips #00 screwdriver.
  7. Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device. Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device. Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device.
    • Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device.
  8. Separate the front and back casing.
    • Separate the front and back casing.
  9. Once inside the device, find the half that contains the motherboard of the device.
    • Once inside the device, find the half that contains the motherboard of the device.
  10. Use precision tweezers to gently pull out the USB connection from the motherboard.
    • Use precision tweezers to gently pull out the USB connection from the motherboard.
  11. Remove the  audio connector from the motherboard (red and black cables). Using the plastic opening tool, lift the connectors from all sides before pulling it with your fingers.
    • Remove the audio connector from the motherboard (red and black cables).
    • Using the plastic opening tool, lift the connectors from all sides before pulling it with your fingers.
    • Do not pull off the connectors by the cables. This could damage the connection from the speaker to the motherboard.
  12. Use precision tweezers to remove the connector joining the LCD and the motherboard. Use precision tweezers to remove the connector joining the LCD and the motherboard.
    • Use precision tweezers to remove the connector joining the LCD and the motherboard.
  13. Remove the six 2.00mm screws with Phillips #00 screwdriver. Remove the six 2.00mm screws with Phillips #00 screwdriver.
    • Remove the six 2.00mm screws with Phillips #00 screwdriver.
  14. Lift motherboard from top left side and pull away gently. Lift motherboard from top left side and pull away gently. Lift motherboard from top left side and pull away gently.
    • Lift motherboard from top left side and pull away gently.
  15. Use the precision tweezers, to gently pull and remove the connector connecting lens and motherboard.
    • Use the precision tweezers, to gently pull and remove the connector connecting lens and motherboard.
  16. Using the precision tweezers, lift silver heat sync tape from motherboard. Using the precision tweezers, lift silver heat sync tape from motherboard.
    • Using the precision tweezers, lift silver heat sync tape from motherboard.
  17. Turn the motherboard over. Use Phillips #00 screwdriver to unscrew four 4mm screws holding the camera lens to the motherboard.
    • Turn the motherboard over.
    • Use Phillips #00 screwdriver to unscrew four 4mm screws holding the camera lens to the motherboard.
  18. Gently grab the lens with your fingers and pull it away from the motherboard. Camera lens should easily come off the motherboard when the last screw is loose.
    • Gently grab the lens with your fingers and pull it away from the motherboard.
    • Camera lens should easily come off the motherboard when the last screw is loose.
Conclusie
Haya Barakat
521 Reputatie
5 handleidingen geschreven
USF Tampa, Team 3-6, Sullivan Fall 2016 Lid van USF Tampa, Team 3-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G6
4 Leden
13 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 128
