Inleiding
For the user to remove the camera lens of the Samsung HMX-W200, they will first need to remove the components protecting the lens.
Wat je nodig hebt
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Once inside the device, find the half that contains the motherboard of the device.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use the precision tweezers, to gently pull and remove the connector connecting lens and motherboard.
Conclusie
