Ga door naar hoofdinhoud
Samsung HMX-QF20 Internal Microphone Replacement
Wat je nodig hebt
  1. Samsung HMX-QF20 Internal Microphone Replacement, Lens: stap 1, afbeelding 1 van 1
    • Remove the 4 mm screw on the underside of the camcorder near the tripod mount.
  2. Samsung HMX-QF20 Internal Microphone Replacement: stap 2, afbeelding 1 van 1
    • Remove the 4 mm screw next to the buckle of the hand strap closest to the lens.
  3. Samsung HMX-QF20 Internal Microphone Replacement: stap 3, afbeelding 1 van 1
    • Open the LCD screen. Remove the 4 mm screw on the inside panel, located at top left corner.
  4. Samsung HMX-QF20 Internal Microphone Replacement: stap 4, afbeelding 1 van 1
    • Firmly grip and pull the front casing on the lens to remove it.
    • Be sure to remove the front casing at gently as possible to prevent damaging the attached ribbon cable. If not careful, the ribbon cables could be torn.
  5. Samsung HMX-QF20 Internal Microphone Replacement: stap 5, afbeelding 1 van 1
    • Remove the three 5 mm screws surrounding the lens.
Conclusie
Ian Dorset
225 Reputatie
2 handleidingen geschreven
Marist, Team 1-5, Laflen Spring 2015 Lid van Marist, Team 1-5, Laflen Spring 2015
MARS-LAFLEN-S15S1G5
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 415
