Inleiding
When the outer lens of an HMX-F90 Camcorder is scratched or scuffed it can require replacement. This guide will show you how to remove the outer lens
Wat je nodig hebt
Pull the release tab away from the battery.
Slide the battery towards the release tab and then pull the battery away from the camcorder.
Rotate the camcorder so that the strap side is facing you.
Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
3 andere personen hebben deze handleiding voltooid.
