Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide will provide a step by step procedure for installing the keypad.
Onderdelen
Geen onderdelen opgegeven.
  1. Using your thumb, press down and slide the back cover away from the  camera.
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Use a Phillips #00 screwdriver to remove the six 4mm screws. Use a Phillips #00 screwdriver to remove the six 4mm screws.
    • Use a Phillips #00 screwdriver to remove the six 4mm screws.
  4. Find a gap on the top side of the phone and pry apart the phone case using the plastic opening tool . Use moderate pressure  to slowly maneuver around until the case is pryed apart. Take the case  off with your fingers
    • Find a gap on the top side of the phone and pry apart the phone case using the plastic opening tool . Use moderate pressure to slowly maneuver around until the case is pryed apart.
    • Take the case off with your fingers
  5. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  6. The green film is  located above the camera. It is the camera connector to the motherboard. Disconnect the camera connector with the plastic opening tool.
    • The green film is located above the camera. It is the camera connector to the motherboard.
    • Disconnect the camera connector with the plastic opening tool.
  7. Take a close up of the picture for this step for a better view. Use a plastic opening tool to disconnect the keyboard connector.
    • Take a close up of the picture for this step for a better view.
    • Use a plastic opening tool to disconnect the keyboard connector.
  8. The motherboard is held in place by the circular connector. Using a plastic opening tool, disconnect the circular connector.
    • The motherboard is held in place by the circular connector.
    • Using a plastic opening tool, disconnect the circular connector.
  9. A LCD connector is located underneath the motherboard. Lift the far edge of the motherboard gently upwards toward the center. Using a plastic opening tool, disconnect the LCD connector.
    • A LCD connector is located underneath the motherboard.
    • Lift the far edge of the motherboard gently upwards toward the center.
    • Using a plastic opening tool, disconnect the LCD connector.
  10. Lift the motherboard up with your fingers. Place the motherboard in a secure area.
    • Lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
  11. Look for the antenna which is located at the bottom end of the device.  Prop the antenna out by using the plastic opening tool and slipping the tip of the tool into the edges of the antenna. Using the plastic opening tool, disconnect the connector that leads from the phone to the antenna. With your hands finish prying apart the antenna  by lifting it up.
    • Look for the antenna which is located at the bottom end of the device. Prop the antenna out by using the plastic opening tool and slipping the tip of the tool into the edges of the antenna.
    • Using the plastic opening tool, disconnect the connector that leads from the phone to the antenna.
    • With your hands finish prying apart the antenna by lifting it up.
  12. The keyboard chip is located on top of the device. Pry the keyboard off of the case with  the plastic opening tool. The keyboard chip is located on top of the device. Pry the keyboard off of the case with  the plastic opening tool.
    • The keyboard chip is located on top of the device. Pry the keyboard off of the case with the plastic opening tool.
  13. To remove the keypad, slide out the display, and poke the keypad out. To remove the keypad, slide out the display, and poke the keypad out.
    • To remove the keypad, slide out the display, and poke the keypad out.
Conclusie
Jimmy La
56 Reputatie
1 Handleiding geschreven
Cal Poly, Team 3-12, Regan Fall 2011 Lid van Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Leden
14 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 892
