Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Samsung Glyde Camera Replacement
Wat je nodig hebt
  1. Samsung Glyde Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde Camera Replacement, Motherboard: stap 3, afbeelding 1 van 2 Samsung Glyde Camera Replacement, Motherboard: stap 3, afbeelding 2 van 2
    • Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
  4. Samsung Glyde Camera Replacement: stap 4, afbeelding 1 van 2 Samsung Glyde Camera Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  5. Samsung Glyde Camera Replacement: stap 5, afbeelding 1 van 2 Samsung Glyde Camera Replacement: stap 5, afbeelding 2 van 2
    • The green film above the camera is the camera connector to the motherboard.
    • Use a plastic opening tool to disconnect the camera connector.
  6. Samsung Glyde Camera Replacement: stap 6, afbeelding 1 van 2 Samsung Glyde Camera Replacement: stap 6, afbeelding 2 van 2
    • The golden film connector connects the keyboard to the motherboard.
    • Use a plastic opening tool to disconnect the keyboard connector.
  7. Samsung Glyde Camera Replacement: stap 7, afbeelding 1 van 2 Samsung Glyde Camera Replacement: stap 7, afbeelding 2 van 2
    • The circular connector holds the motherboard in place.
    • Using a plastic opening tool, disconnect the circular connector.
  8. Samsung Glyde Camera Replacement: stap 8, afbeelding 1 van 3 Samsung Glyde Camera Replacement: stap 8, afbeelding 2 van 3 Samsung Glyde Camera Replacement: stap 8, afbeelding 3 van 3
    • There is a LCD connector underneath the motherboard.
    • Gently lift the far edge of the motherboard upwards toward the center of the phone.
    • Using a plastic opening tool, disconnect the LCD connector.
  9. Samsung Glyde Camera Replacement: stap 9, afbeelding 1 van 2 Samsung Glyde Camera Replacement: stap 9, afbeelding 2 van 2
    • After disconnecting the four connectors, gently lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
  10. Samsung Glyde Camera Replacement, Camera: stap 10, afbeelding 1 van 2 Samsung Glyde Camera Replacement, Camera: stap 10, afbeelding 2 van 2
    • Use your thumb and index finger to grip the camera connector.
    • Pull the camera connector upwards to detach the camera.
    • The camera was glued on, so this may require moderate strength.
Conclusie
Cameron Law
142 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-12, Regan Fall 2011 Lid van Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 890
