Ga door naar hoofdinhoud
Samsung Gear VR with Controller Motherboard Replacement
Wat je nodig hebt
  1. Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: stap 1, afbeelding 1 van 3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: stap 1, afbeelding 2 van 3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: stap 1, afbeelding 3 van 3
    • Turn the controller upside down to access the battery compartment.
    • The battery compartment is located on the opposite side of the buttons.
    • Press on the top of the battery plate and slide down to remove the cover.
  2. Samsung Gear VR with Controller Motherboard Replacement: stap 2, afbeelding 1 van 3 Samsung Gear VR with Controller Motherboard Replacement: stap 2, afbeelding 2 van 3 Samsung Gear VR with Controller Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Remove the AAA batteries using your fingers.
  3. Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: stap 3, afbeelding 1 van 2 Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: stap 3, afbeelding 2 van 2
    • Remove the four 5mm Phillips #000 screws.
  4. Samsung Gear VR with Controller Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use the metal spudger to pry the back side of the controller apart from the front.
    • You will have to use the spudger in many different spots along the divide before trying to separate the pieces.
  5. Samsung Gear VR with Controller Motherboard Replacement: stap 5, afbeelding 1 van 2 Samsung Gear VR with Controller Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Pull apart the two halves of the controller to access the motherboard.
  6. Samsung Gear VR with Controller Motherboard Replacement: stap 6, afbeelding 1 van 3 Samsung Gear VR with Controller Motherboard Replacement: stap 6, afbeelding 2 van 3 Samsung Gear VR with Controller Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Pry on the two pop connectors with the plastic opening tool to detach the motherboard.
    • Separate the motherboard and trackpad from the rear part of the controller.
Conclusie
Jake Criscione
587 Reputatie
3 handleidingen geschreven
Cal Poly, Team S18-G3, White Winter 2019 Lid van Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 953
