Ga door naar hoofdinhoud
Samsung Gear VR USB Connector Replacement
  1. Samsung Gear VR USB Connector Replacement, USB Connector Replacement: stap 1, afbeelding 1 van 1
    • Remove front cover from headset.
  2. Samsung Gear VR USB Connector Replacement: stap 2, afbeelding 1 van 1
    • Slide the latch to the right to unlock the current connector.
  3. Samsung Gear VR USB Connector Replacement: stap 3, afbeelding 1 van 2 Samsung Gear VR USB Connector Replacement: stap 3, afbeelding 2 van 2
    • Lift connector clip away from headset and towards you.
    • Slide current connector out and away from headset until it is disconnected from connector clip.
  4. Samsung Gear VR USB Connector Replacement: stap 4, afbeelding 1 van 1
    • Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
    • The Samsung Gear VR is packaged with connectors for Micro USB and USB-C.
  5. Samsung Gear VR USB Connector Replacement: stap 5, afbeelding 1 van 2 Samsung Gear VR USB Connector Replacement: stap 5, afbeelding 2 van 2
    • Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
    • Slide the lock latch to the left to secure the connector into place.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Alfredo Aparicio
313 Reputatie
3 handleidingen geschreven
USF Tampa, Team S4-G6, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Leden
7 handleidingen geschreven
5 opmerkingen
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - Antwoord
Were do I get the USB c adapter
helenpaul77 - Antwoord
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron -
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh -
Where can I get micro USB converter for gear vr not type c
Molefi Aaron - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 97
Altijd: 15,893
