Ga door naar hoofdinhoud
Samsung Gear VR Lens Replacement
Wat je nodig hebt
  1. Samsung Gear VR Lens Replacement, Front Phone Mount: stap 1, afbeelding 1 van 3 Samsung Gear VR Lens Replacement, Front Phone Mount: stap 1, afbeelding 2 van 3 Samsung Gear VR Lens Replacement, Front Phone Mount: stap 1, afbeelding 3 van 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Lens Replacement: stap 2, afbeelding 1 van 2 Samsung Gear VR Lens Replacement: stap 2, afbeelding 2 van 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR Lens Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR Lens Replacement: stap 4, afbeelding 1 van 1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
  5. Samsung Gear VR Lens Replacement, Inner Mask: stap 5, afbeelding 1 van 3 Samsung Gear VR Lens Replacement, Inner Mask: stap 5, afbeelding 2 van 3 Samsung Gear VR Lens Replacement, Inner Mask: stap 5, afbeelding 3 van 3
    • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
    • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
  6. Samsung Gear VR Lens Replacement, Lens: stap 6, afbeelding 1 van 2 Samsung Gear VR Lens Replacement, Lens: stap 6, afbeelding 2 van 2
    • Using the metal spudger, push in the 3 tabs around the lens housing to release the lens. Repeat for both lens for a total of 6 tabs.
    • Do not push in too hard or you might brake the tabs.
  7. Samsung Gear VR Lens Replacement: stap 7, afbeelding 1 van 1
    • Flip the headgear and use your fingers to gently remove lens from mask. Repeat for both lens.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Abraham Rodriguez
236 Reputatie
2 handleidingen geschreven
USF Tampa, Team S4-G6, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Leden
7 handleidingen geschreven
Één opmerking
There are multiple mistakes in this tutorial, which made it hard to follow the steps:
- in step 2.1, you are missing 4 screws below each side of the latching mechanism.
- in step 5, the mask does not come apart after unscrewing the 8 screws. I am currently stuck at this step as I am writing this. Wish me luck.
L.H. - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 36
Altijd: 5,877
