Ga door naar hoofdinhoud
Samsung Gear VR Front Phone Mount Replacement
Wat je nodig hebt
  1. Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: stap 1, afbeelding 1 van 3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: stap 1, afbeelding 2 van 3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: stap 1, afbeelding 3 van 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Front Phone Mount Replacement: stap 2, afbeelding 1 van 2 Samsung Gear VR Front Phone Mount Replacement: stap 2, afbeelding 2 van 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Garrett Moncrief
179 Reputatie
1 Handleiding geschreven
USF Tampa, Team S4-G6, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 1,179
