Ga door naar hoofdinhoud
Samsung Gear VR Motherboard Replacement
Wat je nodig hebt
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: stap 1, afbeelding 1 van 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: stap 1, afbeelding 2 van 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: stap 1, afbeelding 3 van 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR  Motherboard Replacement: stap 2, afbeelding 1 van 2 Samsung Gear VR  Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR  Motherboard Replacement: stap 4, afbeelding 1 van 1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
Conclusie
David Forlano
119 Reputatie
1 Handleiding geschreven
USF Tampa, Team S4-G6, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Leden
7 handleidingen geschreven
Één opmerking
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 1,471
