Ga door naar hoofdinhoud
Samsung Gear S3 Frontier Wristband Replacement
Video overzicht
  1. Samsung Gear S3 Frontier Wristband  Replacement, Wristband: stap 1, afbeelding 1 van 3 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: stap 1, afbeelding 2 van 3 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: stap 1, afbeelding 3 van 3
    • Place the watch screen-down so that its back cover is showing.
    • Use your nail to push the small silver ball bearing on the right side downward.
    • If your nails aren't sharp enough, you can use a sharp pointed object such as a toothpick or pen.
    • While the ball is pressed down, pull the wristband outwards until the strap is disconnected from the main frame.
    • For reassembly, hold the ball down and then wedge each pin on the wristband into the pin holes of the main frame.
    • Follow the same steps for the ball on the left side, except this time push the ball upwards and then pull outwards.
Conclusie
Corey Rumbaugh
1.517 Reputatie
1 Handleiding geschreven
Cal Poly, Team S15-G2, White Fall 2018 Lid van Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 Leden
34 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 35
Altijd: 2,828
