Ga door naar hoofdinhoud
Samsung Gear S3 Frontier Bezel Ring Replacement
Wat je nodig hebt
  1. Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: stap 1, afbeelding 1 van 3 Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: stap 1, afbeelding 2 van 3 Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: stap 1, afbeelding 3 van 3
    • Contains small springs and ball bearings. We suggest working over a plate or tray.
    • Hold the watch firmly in one hand, face up.
    • Place the iFixit Opening Tool under the bezel ring and use prying motion to remove.
    • The plastic retainer is manufactured with an open gap, you did not break it.
    • For reassembly, set the plastic retainer in the ring, then press the ring down until it snaps in place.
Conclusie
27 andere personen hebben deze handleiding voltooid.
Mark Iknoian
1.082 Reputatie
1 Handleiding geschreven
Cal Poly, Team S15-G2, White Fall 2018 Lid van Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 Leden
34 handleidingen geschreven
45Gids Commentaar
I got the bezel popped off to clean it. Now it wont pop back on! Help!
shileski - Antwoord
line up the bezel with the screen and push it in
Arthur -
I’ve tried lining it up with the screen and pushing it in about 50 times now and everytime I do it clicks, but after rotating it a few times the bezel locks and I can’t rotate it anymore. YES all the ball bearings are in the right place, YES the springs are in the right place. There’s this little plastic piece that I can’t tell if it goes inside the bezel piece or if it goes on top of the watch next to the ball bearings. I’m able to get the bezel back on when I put the little plastic piece on the bezel, it clicks right in, but it locks up. When I leave the little plastic piece on the watch I can’t get it to click in at all. I think I just royally f’ed up my watch!
Hardy T - Antwoord
put the plastic ring in the bezel first. make sure the the legs on the plastic ring are facing the watch an not the bezel. i lost 2 springs though. be careful when cleaning and tilting.
Robert Payan -
did u manage to fix it?
Dave Green - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 111
Afgelopen 30 dagen: 387
Altijd: 92,678
