Ga door naar hoofdinhoud
Samsung Gear S2 Watch Strap Replacement
Wat je nodig hebt
  1. Samsung Gear S2 Watch Strap Replacement, Watch Strap: stap 1, afbeelding 1 van 2 Samsung Gear S2 Watch Strap Replacement, Watch Strap: stap 1, afbeelding 2 van 2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
    The warning to turn off the watch to avoid electrical shock was a joke, right?!
    nanev - Antwoord
    The screws don't seem to be turning easily. What's the best way to loosen them without stripping them?
    Mark Franz - Antwoord
    I’m going to be shocked by a dead 3.8V battery? Of course, only if the watch is powered on. Ridiculous statements like this do not reflect positively on the credibility of this entire procedure. If the author seriously thinks this is a danger then I question your basic understanding of electronics.
    Alex Tatistcheff - Antwoord
    … to avoid being shocked when you lose your data! :)
    Reuben Janzen-Martin - Antwoord
  2. Samsung Gear S2 Watch Strap Replacement: stap 2, afbeelding 1 van 2 Samsung Gear S2 Watch Strap Replacement: stap 2, afbeelding 2 van 2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
    The bracelet should be removed first!
    Das Armband sollte zuerst entfernt werden!
    Wilhelm Gregorius - Antwoord
  3. Samsung Gear S2 Watch Strap Replacement: stap 3, afbeelding 1 van 2 Samsung Gear S2 Watch Strap Replacement: stap 3, afbeelding 2 van 2
    • Repeat the procedure from step 2 for the other strap.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Jacob Baldwin
3.412 Reputatie
5 handleidingen geschreven
USF Tampa, Team S2-G3, Sullivan Spring 2017 Lid van USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
3 Leden
23 handleidingen geschreven
6 opmerkingen
can you also provide instruction to change home button on Gear S2
thanks
inder kapoor - Antwoord
you have to buy the continuing transfunctioner to change the home button on the gear s2
i have some for sale if interested
bobby - Antwoord
Where can you buy new straps?
Olga Andreu - Antwoord
Ebay Amazon etc.
Jens Troemer - Antwoord
YOU DO NOT NEED TO REMOVE THE SCREWS. Step 1 is completely irrelevant.
Ryo Kimball - Antwoord
How can I take the metal piece that was broken off from the strap, that's stuck to the watch
Vang Lesh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 61
Altijd: 9,287
