Ga door naar hoofdinhoud
Samsung Gear S2 Watch Strap Replacement
Wat je nodig hebt
  1. Samsung Gear S2 Watch Strap Replacement, Watch Strap: stap 1, afbeelding 1 van 2 Samsung Gear S2 Watch Strap Replacement, Watch Strap: stap 1, afbeelding 2 van 2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Watch Strap Replacement: stap 2, afbeelding 1 van 2 Samsung Gear S2 Watch Strap Replacement: stap 2, afbeelding 2 van 2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Watch Strap Replacement: stap 3, afbeelding 1 van 2 Samsung Gear S2 Watch Strap Replacement: stap 3, afbeelding 2 van 2
    • Repeat the procedure from step 2 for the other strap.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Jacob Baldwin
3.412 Reputatie
5 handleidingen geschreven
USF Tampa, Team S2-G3, Sullivan Spring 2017 Lid van USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
3 Leden
23 handleidingen geschreven
6 opmerkingen
can you also provide instruction to change home button on Gear S2
thanks
inder kapoor - Antwoord
you have to buy the continuing transfunctioner to change the home button on the gear s2
i have some for sale if interested
bobby - Antwoord
Where can you buy new straps?
Olga Andreu - Antwoord
Ebay Amazon etc.
Jens Troemer - Antwoord
YOU DO NOT NEED TO REMOVE THE SCREWS. Step 1 is completely irrelevant.
Ryo Kimball - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 61
Altijd: 9,519
