Ga door naar hoofdinhoud
Samsung Gear S2 Battery Replacement
Wat je nodig hebt
  1. Samsung Gear S2 Battery Replacement, Watch Strap: stap 1, afbeelding 1 van 2 Samsung Gear S2 Battery Replacement, Watch Strap: stap 1, afbeelding 2 van 2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Battery Replacement: stap 2, afbeelding 1 van 2 Samsung Gear S2 Battery Replacement: stap 2, afbeelding 2 van 2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Battery Replacement: stap 3, afbeelding 1 van 2 Samsung Gear S2 Battery Replacement: stap 3, afbeelding 2 van 2
    • Repeat the procedure from step 2 for the other strap.
  4. Samsung Gear S2 Battery Replacement, Back: stap 4, afbeelding 1 van 2 Samsung Gear S2 Battery Replacement, Back: stap 4, afbeelding 2 van 2
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
  5. Samsung Gear S2 Battery Replacement, Motherboard: stap 5, afbeelding 1 van 2 Samsung Gear S2 Battery Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
  6. Samsung Gear S2 Battery Replacement: stap 6, afbeelding 1 van 3 Samsung Gear S2 Battery Replacement: stap 6, afbeelding 2 van 3 Samsung Gear S2 Battery Replacement: stap 6, afbeelding 3 van 3
    • Using a spudger, pry up the three cables.
  7. Samsung Gear S2 Battery Replacement: stap 7, afbeelding 1 van 2 Samsung Gear S2 Battery Replacement: stap 7, afbeelding 2 van 2
    • Using the flat end of a spudger, pry up the motherboard.
    • Make sure the cable is fed through the hole to avoid damaging it.
    • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
  8. Samsung Gear S2 Battery Replacement, Battery: stap 8, afbeelding 1 van 2 Samsung Gear S2 Battery Replacement, Battery: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, lift the battery casing.
    • Make sure the cables are fed through their gaps to avoid damaging them.
  9. Samsung Gear S2 Battery Replacement: stap 9, afbeelding 1 van 2 Samsung Gear S2 Battery Replacement: stap 9, afbeelding 2 van 2
    • Flip the battery casing over and using a spudger, push on the battery to free it from the casing.
    • Once the battery is free, use the flat end of a spudger to lift up the battery cable.
Conclusie
100 andere personen hebben deze handleiding voltooid.
Jacob Baldwin
3.412 Reputatie
5 handleidingen geschreven
USF Tampa, Team S2-G3, Sullivan Spring 2017 Lid van USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
3 Leden
23 handleidingen geschreven
39 opmerkingen
Excellent guidelines, and do you have steps for s3 frontier
pedro tiburcio - Antwoord
A reference to the battery part number would be great.
Harold Turner - Antwoord
Very good job and very easy
JEAN PIERRE - Antwoord
I have the Gear S2 3G version R730V and purchased a battery thinking these instructions would work, but once I opened the watch it is not the same as the one above. Does anyone have instructions on how to replace the batter on the R730V??
Irene - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 81
Afgelopen 30 dagen: 400
Altijd: 154,200
