Ga door naar hoofdinhoud
Samsung Gear Fit Screen Replacement
Wat je nodig hebt
  1. Samsung Gear Fit Screen Replacement, Watch Band: stap 1, afbeelding 1 van 2 Samsung Gear Fit Screen Replacement, Watch Band: stap 1, afbeelding 2 van 2
    • Place your thumbs on the ends of the screen.
    • Push the watch outward while pulling the band away from the watch.
  2. Samsung Gear Fit Screen Replacement, Screen: stap 2, afbeelding 1 van 1
    • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
    • For step-by-step instructions on using an iOpener, see the Instructies voor de iOpener.
    • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
  3. Samsung Gear Fit Screen Replacement: stap 3, afbeelding 1 van 3 Samsung Gear Fit Screen Replacement: stap 3, afbeelding 2 van 3 Samsung Gear Fit Screen Replacement: stap 3, afbeelding 3 van 3
    • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
    • Gently pry the screen loose using a plastic opening tool.
    • If the screen doesn't easily come loose, more heating may be required
  4. Samsung Gear Fit Screen Replacement: stap 4, afbeelding 1 van 3 Samsung Gear Fit Screen Replacement: stap 4, afbeelding 2 van 3 Samsung Gear Fit Screen Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers as a lever, pry the inner assembly out of the external casing.
    • This will be harder than removing the screen. Moderate force may be required.
  5. Samsung Gear Fit Screen Replacement: stap 5, afbeelding 1 van 3 Samsung Gear Fit Screen Replacement: stap 5, afbeelding 2 van 3 Samsung Gear Fit Screen Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
  6. Samsung Gear Fit Screen Replacement: stap 6, afbeelding 1 van 2 Samsung Gear Fit Screen Replacement: stap 6, afbeelding 2 van 2
    • Gently peel the screen assembly up and away from the device using tweezers.
Conclusie
17 andere personen hebben deze handleiding voltooid.
Nathan Powell
1.577 Reputatie
3 handleidingen geschreven
Cal Poly, Team 11-49, Amido Spring 2014 Lid van Cal Poly, Team 11-49, Amido Spring 2014
CPSU-AMIDO-S14S11G49
4 Leden
4 handleidingen geschreven
28 opmerkingen
Hi!
Thank you very much for this tuto. But wher can we acquire the screen ???
Thanks a lot.
AB
aaa - Antwoord
Where can you buy replacement screen?
Yele Olaniyi - Antwoord
I'm also finding it difficult to buy a replacement screen too. Has anyone discovered some. I thought this website was selling some not too long ago. Any more coming in?
Rochelle - Antwoord
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
alexxtodorov - Antwoord
Does anyone know where to get the replacement screen?
MrGratts - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 40
Altijd: 53,530
