Ga door naar hoofdinhoud
Samsung Gear 360 Battery Replacement
  1. Samsung Gear 360 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert thumb under tab of battery cover.
    • Pull to remove the battery cover.
  2. Samsung Gear 360 Battery Replacement: stap 2, afbeelding 1 van 2 Samsung Gear 360 Battery Replacement: stap 2, afbeelding 2 van 2
    • Once the cover is opened, press index finger on the tab to release the battery from the battery slot.
  3. Samsung Gear 360 Battery Replacement: stap 3, afbeelding 1 van 1
    • Once the battery has popped out, pull the battery out of the camera.
Conclusie
Angel Veras
107 Reputatie
1 Handleiding geschreven
USF Tampa, Team S3-G5, Sullivan Spring 2017 Lid van USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
4 Leden
14 handleidingen geschreven
Één opmerking
I charged one battery successfully and proceeded to remove the battery and insert another battery to charge. The camera died and would not charge the second battery, so I re-inserted the charged battery and now the camera will not power up. Any ideas?
Mark Newsom - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 60
Altijd: 6,343
