Ga door naar hoofdinhoud
Inleiding
If your home button is smashed in, or isn't functioning properly then this guide will show you step-by-step instructions for home button replacement. This is very easy rated at 3 out of 10. and should only take 5 minutes.
  1. Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
    • Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
  2. Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch. Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
    • Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
  3. Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
    • Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
  4. Use a pair of tweezers to peel the battery ribbon cable off of the back cover. Avoid damaging the gold terminals on the ribbon cable.
    • Use a pair of tweezers to peel the battery ribbon cable off of the back cover.
    • Avoid damaging the gold terminals on the ribbon cable.
    • When reassembling, make sure that the yellow strip snaps back on to the black pin.
    • The pin is located, and marked on the picture.
    • Pull up on the tab that says, “Pull”, the battery will lift straight out.
  5. Using the plastic opening tool, pull up on the flex connector.  It will come off the motherboard, but will stay attached to the cover like a hinge.
    • Using the plastic opening tool, pull up on the flex connector. It will come off the motherboard, but will stay attached to the cover like a hinge.
  6. It is recommended to use antistatic wrist wrap whenever removing the motherboard.
    • It is recommended to use antistatic wrist wrap whenever removing the motherboard.
    • Place the plastic opening tool underneath the motherboard at this location. Gently pry the motherboard away from the front cover. It should pop off and be free from the cover.
    • Attached to the motherboard is the infrared LED Light. To replace the IR LED, you may need to replace the entire motherboard.
  7. Using fine tweezers, pull the home button ribbon cable up and away from the front cover.
    • Using fine tweezers, pull the home button ribbon cable up and away from the front cover.
    • Like with the battery's ribbon cable, there is a pin that holds the pad in place. It is in the area marked. However, the models' pin had be broken.
  8. Using the plastic opening tool, pry the home button away from the front cover.
    • Using the plastic opening tool, pry the home button away from the front cover.
    • The whole home button mechanism should lift right out.
Conclusie
Victor Yore
705 Reputatie
5 handleidingen geschreven
USF Tampa, Team 5-6, Blackwell Fall 2015 Lid van USF Tampa, Team 5-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G6
3 Leden
Één commentaar
do you know where i purchase the actual button?
Nolan M Charbonnet Sr. - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 962
