Ga door naar hoofdinhoud
Samsung Galaxy View Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy View Battery Replacement, Kickstand: stap 1, afbeelding 1 van 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Battery Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy View Battery Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy View Battery Replacement: stap 2, afbeelding 3 van 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Samsung Galaxy View Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Battery Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy View Battery Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy View Battery Replacement: stap 4, afbeelding 3 van 3
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Battery Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy View Battery Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy View Battery Replacement: stap 5, afbeelding 3 van 3
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Battery Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy View Battery Replacement: stap 6, afbeelding 2 van 2
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Battery Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy View Battery Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy View Battery Replacement: stap 7, afbeelding 3 van 3
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
Conclusie
40 andere personen hebben deze handleiding voltooid.
Roger Pena
1.141 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-5, Livingston Fall 2016 Lid van Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Leden
12 handleidingen geschreven
29 opmerkingen
I’m not sure if it’s the battery or the cord
Swheet - Antwoord
What size is the battery that fits into the SAMSUNG TAB VIEW?
Ricky Lee Lidel - Antwoord
Thank You, Sooo much. This guide is a true money and time saver. Worked like a gem .
Mike Rowe - Antwoord
I can't find Lithium ION 11.3 V 5700mAh battery for my Samsung Galaxy 18.4View Tablet, does anyone know where to get one?
What's difference between a 5700mAh battery and 5900mAh battery
Sue ELLEN R FONTENOT - Antwoord
Where can I find battery replacement for galaxy view
Greg Dover -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 165
Altijd: 25,085
