Ga door naar hoofdinhoud
Samsung Galaxy TabPro S Screen Replacement
Wat je nodig hebt
  1. Samsung Galaxy TabPro S Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Apply heat around the screen to loosen the glue holding in the screen. A heat gun would be preferable as it needs to get relatively warm.
  2. Samsung Galaxy TabPro S Screen Replacement: stap 2, afbeelding 1 van 1
    • Attach the small suction cup near the edge of the screen.
    • Pry in between the screen and the frame with a plastic spudger.
    • Pull up with the suction cup while prying and the screen should begin gently disconnecting.
    • Use the spudger on all edges of the tablet between the screen and the frame.
    • The screen should release.
  3. Samsung Galaxy TabPro S Screen Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the thick cable from the motherboard
    • Disconnect the golden cable from the motherboard
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mitchell Caister
328 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-4, Harley Spring 2022 Lid van IUPUI, Team 3-4, Harley Spring 2022
IUPUI-HARLEY-S22S3G4
3 Leden
Één opmerking
Where to find a replacement screen for a 2017 Samsung tab S pro 12 inch ?!?!?
ori gosi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 760
