Ga door naar hoofdinhoud
Samsung Galaxy TabPro S Front-Facing Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: stap 1, afbeelding 1 van 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: stap 1, afbeelding 2 van 2
    • Remove the back of the tablet by prying the plastic back using a flat tool.
    • When the tool has been inserted under the back, slide it all the way around the tablet to fully unclip it.
    Vraag FixBot
  2. Samsung Galaxy TabPro S Front-Facing Camera Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Once the back has been removed, disconnect all cables using a pair of tweezers to avoid damaging any components.
    • Once the cables have been disconnected, remove the battery using a flat plastic tool (not the metal spudger).
    Vraag FixBot
  3. Samsung Galaxy TabPro S Front-Facing Camera Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the screws that secure the motherboard.
    • Remove the metal plate once the screws are gone and the motherboard will be ready to be replaced.
    Vraag FixBot
  4. Samsung Galaxy TabPro S Front-Facing Camera Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: stap 4, afbeelding 2 van 2
    • Remove motherboard by prying it up with a flat plastic opening tool (not metal spudger).
    • Be sure that all components have been disconnected beforehand, especially the front-facing camera (located above the motherboard in the top center of the frame).
    Vraag FixBot
  5. Samsung Galaxy TabPro S Front-Facing Camera Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: stap 5, afbeelding 2 van 2
    • Once the camera has been disconnected from the motherboard, it can be removed using a pair of pliers.
    Vraag FixBot
Conclusie
Mitchell Caister
367 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-4, Harley Spring 2022 Lid van IUPUI, Team 3-4, Harley Spring 2022
IUPUI-HARLEY-S22S3G4
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 45
Altijd: 621
