Inleiding
This guide explains how to replace a faulty Micro SD card reader in the Samsung Galaxy S3. This requires getting in the device, which with Samsung means lots of glue, so come equipped with an iOpener or heat gun. Once inside, the Micro SD card tray is totally modular, and is easy to remove and replace. You’ll need to replace the Micro SD card reader if your device doesn’t recognize or has trouble transferring data to or from a Micro SD card.
Wat je nodig hebt
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
Disconnect the single press fit connector located just above the Micro SD card tray on the left midframe.
