Ga door naar hoofdinhoud
Samsung Galaxy Tab S3 Front Facing Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Display: stap 1, afbeelding 1 van 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
    There is no reason to remove the screen while replacing a battery.
    Nick Youngstrom - Antwoord
    Agreed , just remove back and warm up. Dont remove screen, is $220 to replace off ebay.
    Phenix City - Antwoord
  2. Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 2, afbeelding 1 van 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
    Bonjour, pour moi il est IMPÉRATIF d’opérer l’ouverture par le bord droit comme indiqué sur le tuto car de l’autre coté les nappes du LCD ne sont qu’à 3mm du bord et peuvent etre abimée comme je l’ai fait lors du décollage.
    Jacques Barreau - Antwoord
  3. Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
    For this part I recommend to insert the tools only on top, bottom and right side. Then lift the screen as shown in the pictures in step 4. The left side has the light ribbons for the display too close to the edge and they are really thin. I just broke the four of them in my screen :(
    Moisés Jover - Antwoord
  4. Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 4, afbeelding 3 van 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Rear glass panel: stap 5, afbeelding 1 van 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Rear glass panel: stap 5, afbeelding 2 van 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Battery: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Battery: stap 6, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 7, afbeelding 1 van 1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 8, afbeelding 1 van 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 8, afbeelding 2 van 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 8, afbeelding 3 van 3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 9, afbeelding 1 van 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 9, afbeelding 2 van 2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 10, afbeelding 2 van 2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 11, afbeelding 1 van 1
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: stap 12, afbeelding 1 van 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: stap 12, afbeelding 2 van 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: stap 12, afbeelding 3 van 3
    • Using a nylon spudger, carefully push the camera out of its framing.
    • Unlike the rear facing camera, you will be pushing this camera out from the front. Try to push on the side of the camera so as to not damage the lens with the pointy end of the spudger.
  13. Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 13, afbeelding 1 van 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 13, afbeelding 2 van 2
    • Carefully pop the front facing camera off from the motherboard with the flat end of the spudger.
  14. Samsung Galaxy Tab S3 Front Facing Camera Replacement: stap 14, afbeelding 1 van 1
    • Remove the front facing camera from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Justin Ogihara
27.166 Reputatie
52 handleidingen geschreven
EDU Team Lid van EDU Team
Staff
7 Leden
637 handleidingen geschreven
Één opmerking
This repair can be done without removing the screen!
hansderaedt - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 360
