Ga door naar hoofdinhoud
Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Turn off the tablet before disassembly.
    • Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
  2. Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 2, afbeelding 2 van 2
    • The glue is now melted, so using the metal spudger shown, pry open all sides of the tablet.
    • When prying open near the home and touch screen buttons, use a suction cup.
    • Do not stick the metal spudger past these buttons as this may damage your device.
  3. Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 3, afbeelding 2 van 2
    • Carefully lift up the screen.
    • There is a ribbon cable attached. Lifting the screen too quickly can damage the cable.
  4. Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 4, afbeelding 3 van 3
    • Remove the ribbon cable using the Metal Spudger.
    • The ribbon may be taped underneath to the grey frame. Gently lift the ribbon to untape it.
  5. Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 5, afbeelding 2 van 2
    • Remove all seventeen 3 mm screws using a PH000 Phillips screwdriver.
  6. Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 6, afbeelding 1 van 3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 6, afbeelding 2 van 3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 6, afbeelding 3 van 3
    • Lift the black frame using the two Metal Spudgers shown.
    • On the third picture, there is a Sim Card component that is connected to the frame and back cover. As you lift up the frame, it'll detach. This is normal.
  7. Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 7, afbeelding 1 van 1
    • Once lifted, flip the grey frame over.
    • This component connects to the sim card.
    • Remember to click this component back into place when reassembling the tablet.
  8. Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement, Auxiliary Port: stap 8, afbeelding 1 van 2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement, Auxiliary Port: stap 8, afbeelding 2 van 2
    • This is where the auxiliary port is located.
    • Remove the black 3mm screw using a PH000 Phillips screwdriver.
  9. Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 9, afbeelding 1 van 2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Auxiliary Port Replacement: stap 9, afbeelding 2 van 2
    • Unclip the ribbon using the Blunt ESD Tweezer.
    • Lift up the auxiliary port using the Blunt ESD Tweezer.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Divya Prabakaran
633 Reputatie
6 handleidingen geschreven
USF Tampa, Team S2-G4, Sullivan Spring 2017 Lid van USF Tampa, Team S2-G4, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G4
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 624
