Ga door naar hoofdinhoud
Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Screen: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Screen: stap 1, afbeelding 2 van 2
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: stap 2, afbeelding 2 van 2
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: stap 3, afbeelding 1 van 1
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  4. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  5. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: stap 5, afbeelding 1 van 1
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
  6. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Screws: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Screws: stap 6, afbeelding 2 van 2
    • Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
    • Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
    • Put the screws on a magnetic project mat or in a container so that you do not lose them.
  7. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: stap 7, afbeelding 3 van 3
    • Take the plastic opening tool around the tablet to remove the motherboard from the device.
  8. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Camera: stap 8, afbeelding 1 van 3 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Camera: stap 8, afbeelding 2 van 3 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Camera: stap 8, afbeelding 3 van 3
    Koop
    • Locate the two cameras at the top of the motherboard.
    • To remove the bigger, back-facing camera, use the precision tweezers to slide the silver ribbon cable out of the ZIF connector.
  9. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: stap 9, afbeelding 1 van 2 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: stap 9, afbeelding 2 van 2
    • To remove the smaller, front-facing camera, use the precision tweezers to disconnect the press-fit connector.
    • Carefully detach the camera using the precision tweezers.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joy Harris
814 Reputatie
7 handleidingen geschreven
USF Tampa, Team S3-G4, Sullivan Spring 2017 Lid van USF Tampa, Team S3-G4, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G4
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 11
Altijd: 329
