Inleiding
Follow this guide if you need to replace your Samsung Galaxy Tab S2 8.0 screen. If your screen is cracked or not displaying images as it should, replacing it will fix these problems.
Wat je nodig hebt
Video overzicht
Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
Put an opening pick in the gap created, in between the screen and the panel.
Repeat all around device, putting 2 picks on top and bottom, and one on each side.
8 andere personen hebben deze handleiding voltooid.
