Inleiding
If the tablet is taking blurry pictures or unclear pictures, replacing the camera should solve the problem.
Wat je nodig hebt
Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
Put an opening pick in the gap created, in between the screen and the panel.
Repeat all around device, putting 2 picks on top and bottom, and one on each side.
Remove the 13 3mm screws from around the edges of the board using a Phillips #1 screwdriver head.
Één andere persoon heeft deze handleiding voltooid.
