Ga door naar hoofdinhoud
Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: stap 2, afbeelding 1 van 1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: stap 4, afbeelding 1 van 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: stap 4, afbeelding 2 van 2
    • Remove the two 2 mm Phillips #000 securing the headphone jack.
  5. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the blue connector by gently popping it off of the motherboard with a plastic opening tool.
  6. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: stap 6, afbeelding 2 van 2
    • Use the metal spudger to pry from the top left corner of the headphone jack/lower speaker assembly.
    • Gently lift the headphone jack/lower speaker assembly free of the device.
  7. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: stap 7, afbeelding 1 van 1
    • Locate the top speaker.
    • Use a plastic opening tool to disconnect the green-gold upper speaker connector from the motherboard.
  8. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: stap 8, afbeelding 2 van 2
    • Use a spudger to pry the uper speaker up and away from the device.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Trent Chapman
1.378 Reputatie
3 handleidingen geschreven
Cal Poly, Team 12-15, Maness Fall 2015 Lid van Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 3,336
