Ga door naar hoofdinhoud
Samsung Galaxy Tab S 10.5 Headphone Jack Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: stap 1, afbeelding 2 van 2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Back Rim Cover: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Back Rim Cover: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Back Rim Cover: stap 4, afbeelding 3 van 3
    • Place the plastic opening tool in between the outer rim.
    • Move the tool in a downward motion to separate the 2 parts.
    • Run the tool along the rim to disconnect all connectors holding the outer rim to the back of the device.
  5. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: stap 5, afbeelding 1 van 1
    • Repeat this step for all four sides, then remove the rim.
  6. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Headphone Jack: stap 6, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove the two screws holding the headphone jack.
  7. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: stap 7, afbeelding 1 van 1
    • Place the hook of a spudger on the backside of headphone jack and pop the headphone jack out.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 575
