Ga door naar hoofdinhoud
Samsung Galaxy Tab Pro 8.4 Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Remove all the clips that are attached to the motherboard using your fingers or a nylon spudger.
  7. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • There are four Phillips head screws (2.5mm) that need to be removed:
    • Two on the charging port, which is the small metallic piece at the bottom of the device.
    • There is one screw that is covered by a small green tape. The tape must be peeled off before the screw under can be removed.
    • The last screw is found on a speaker at the bottom right of the device. Once the screw is removed, the speaker must be removed as well.
  8. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 8, afbeelding 1 van 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 8, afbeelding 2 van 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • There is a small wire that connects the motherboard to the bottom right corner.
    • Gently pull the end of the wire that attaches the motherboard to the device until the wire is disconnected.
    • After the cord is disconnected, the motherboard can be removed from the tablet by simply lifting it from the device.
Eindstreep
5 andere personen hebben deze handleiding voltooid.
victor johnson
242 Reputatie
1 Handleiding geschreven
USF Tampa, Team 9-2, Lacy Fall 2016 Lid van USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 2,393
