Ga door naar hoofdinhoud
Samsung Galaxy Tab Pro 8.4 Charging Port Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: stap 2, afbeelding 2 van 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: stap 4, afbeelding 1 van 1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: stap 5, afbeelding 1 van 1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: stap 6, afbeelding 2 van 2
    • Remove the two 2.5mm Phillips #000 screws.
  7. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: stap 7, afbeelding 3 van 3
    • Gently pull up on tab that connects the charging port to the motherboard
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jonathan Romine
1.072 Reputatie
2 handleidingen geschreven
USF Tampa, Team 9-2, Lacy Fall 2016 Lid van USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
4 Leden
10 handleidingen geschreven
3 opmerkingen
Thank you for your help. You are awesome :-)
Kim Williams - Antwoord
I did all of this and battery says “not charging” while plugged in. Replaced both battery and port.
Brandon Torzeski - Antwoord
Hey Thanks guys! I was interested in the data port / charging port flex cable replacement.
It could not be easier. Cheers folks.
Jim Kirkey
Jim Kirkey - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 4,042
