Ga door naar hoofdinhoud
Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: stap 1, afbeelding 1 van 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: stap 1, afbeelding 2 van 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: stap 2, afbeelding 2 van 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: stap 8, afbeelding 1 van 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: stap 8, afbeelding 2 van 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nicholas Nolan
805 Reputatie
5 handleidingen geschreven
USF Tampa, Team S19-G2, Hoffman Spring 2017 Lid van USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 1,045
