Ga door naar hoofdinhoud
Samsung Galaxy Tab E Lite 7 Kids Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: stap 1, afbeelding 1 van 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: stap 1, afbeelding 2 van 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: stap 2, afbeelding 2 van 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • Use the plastic opening tool to gently lift the black ZIF (zero insertion force) connector shown within the red circle.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: stap 4, afbeelding 2 van 2
    • Use the plastic opening tool to gently lift black ZIF (zero insertion force) connector shown within the red square.
    • Now gently pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: stap 5, afbeelding 3 van 3
    • Use the plastic opening tool and gently pry out the battery from the left-hand side.
    • Grab the battery and lift it up.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Nicholas Nolan
805 Reputatie
5 handleidingen geschreven
USF Tampa, Team S19-G2, Hoffman Spring 2017 Lid van USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 Leden
7 handleidingen geschreven
Één opmerking
Great information.  You need to show how to replace a screen- LCD for a Samsung Galaxy TAB E Lite Kids.
Paul McWilliams - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 3,026
