Ga door naar hoofdinhoud
Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement
Wat je nodig hebt
Video overzicht
  1. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement, Digitizer (Screen Replacement): stap 1, afbeelding 1 van 2 Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement, Digitizer (Screen Replacement): stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Place the Tablet on a flat surface.
    • Gather the required tools : iFixit opening tool, iFixit opening picks, precision tweezers, suction handle, and spudger.
  2. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: stap 2, afbeelding 1 van 1
    • Place suction handle in the center of the screen. Firmly press it downwards .
    • This is done to help assist lifting the screen once the edges are loose.
  3. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: stap 3, afbeelding 1 van 1
    • Grab the iFixit pening tool and wedge the sharp end into the corner of the screen. Pry it upwards, lifting up the corner of the screen.
  4. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: stap 4, afbeelding 1 van 1
    • Place the iFixit opening pick between the lifted corner and the housing to prevent the screen from falling back into the housing.
  5. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: stap 5, afbeelding 1 van 1
    • Continue around the perimeter of the screen until you have placed the picks in each remaining corner.
    • Be careful removing the double-sided tape while lifting the screen so that the screen does not break.
  6. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: stap 6, afbeelding 1 van 1
    • Grab the suction handle and gently lift the screen towards the top of the tablet.
    • Take care while lifting the screen to avoid damaging the ribbon cable at the top of the tablet.
  7. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: stap 7, afbeelding 1 van 1
    • Place the removed screen that is still attached to the ribbon cable flat on the table.
  8. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: stap 8, afbeelding 1 van 1
    • Grab the iFixit opening tool and wedge the sharp end into the corner of the housing and pry upwards.
    • Place an iFixit opening pick between the housing and the LCD assembly.
  9. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: stap 9, afbeelding 1 van 1
    • Continue along the outer edge of the housing until you have placed an iFixit opening pick in each corner.
  10. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: stap 10, afbeelding 1 van 1
    • Remove the LCD assembly from the housing and place it face down on the table.
  11. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: stap 11, afbeelding 1 van 1
    • Locate the ribbon cable connector on the back of the LCD assembly.
    • Use the spudger to pry the connector tab upwards.
    • Pull the the ribbon cable to remove it from the connector
  12. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: stap 12, afbeelding 1 van 1
    • Once the ribbon cable is removed, pull the screen off of the motherboard and place it to the side.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Juelma
253 Reputatie
1 Handleiding geschreven
IUPUI, Team S4-G4, Wilson Summer 2019 Lid van IUPUI, Team S4-G4, Wilson Summer 2019
IUPUI-WILSON-SU19S4G4
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 45
Altijd: 5,291
